When you select the option to edit the tool table from within Tools Setup File tab, it is not updating the combo box like you do when called from the edit button on the main gui. This also leads to a possible omission in the new code? The old code had TheFrame->GCodeDlg.Interpreter->m_ReadToolFile=true; The new handler does not. Is this flag no longer important? Eric
Group: DynoMotion
Message: 9692
Date: 6/24/2014
Subject: Re: Another small tool table bug
Hi Eric,
Thanks again. This should be fixed in the next Version.
Actually the m_ReadToolFile is no longer needed as the Tool File is always re-read
every time the Interpreter is launched so that it can be externally modified.
